Drive train failure
If you had the original clutch in it, you were going to be replacing it at some point soon anyway. At least that's what you would tell you wife when the credit card bill arrives.
I've seen pinion gears shredded so catastrophically that they just aren't touching the ring gear anymore. Meaning that the car can be pushed around normally.
Just trying to add some personal experience.
and youve basically given me the same gameplan as Elliot and everyone else
Good luck, OP.
i suppose you would be able to roll the car around freely with it in gear if one of the axles came off too though...
so still worth looking at.
although if that is the case you would probly hear it clunking around back there when you move it
Just pointing out that the r&p is a possibility and should be considered, albeit 3rd in the line of the usual suspects~
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
well, i got home and looked at the CV's, they are both very tight and sturdy.
i put it in gear while the car was running and it did as before, nothing, so i gently squeezed it into reverse, i heard the gears start to grind, then i moved it into 4th at an idle and i could hear the sound of something spinning up behind me.
I was on the phone with Elliot and he said that it definitely points to the transaxle, but i wont be able to get the car off the ground until sunday and verify that, which means I wont be driving her to the meet on saturday, but i will be there.
ok, with the assistance and troubleshooting skills of Elliot we have determined fairly conclusively that the spider gears in the transaxle have eaten themselves.
so, now i am in need of a transaxle for my 1987 944 NA
i live in Lake Mary, Florida, if anyone near has one that will fit.
Elliot said '86-88 will will do the job perfectly, after 88 will possibly have different gear ratio, and before 86 wont have the electronic speedometer. i can deal with different gears if need be, but i would like to have a speedo![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
So, give me a buzz please, id like to get this on this weekend, if possible.
88 and 89 would be the most desirable to get, IMHO.
Glad to hear you diagnosed the problem. This is easier to deal with than the clutch.
You should give Ian a call at 944 Online.
http://www.944online.com/cgi-bin/ASI...954+944Garage+
They are located in Florida so you should be able to get it rather quickly.
When the R&P imploded on my N/A, it was cruising in 5th gear at 65 mph. It sounds a heck of a lot like what happened to you. There was no gear crunching, noise, etc. I just no longer could transmit power to the wheels, it was just like the car only had neutral.
Fortunately, N/A transmissions are cheap and easy to replace.
when this happened on my car, it was the coupler or whatever, I'll see if I can find a pic ... its like a $450 part
edit:
![](http://www.944online.com/images/products/transmissions/transcoupler.gif)
http://www.944online.com/cgi-bin/ASI...nsmission-9441
and it looks like now its much cheaper then 2 years ago ...
I heard 1 single pop and my car had trouble getting into gear, its been a while so I don't remember all the details ...
edit:
ok, i got ahold of 944online.com and they want $750 for a transaxle to fit my car (+shipping),id rather find one a bit cheaper then that. so im still in the market!
edit://
http://www.streetsmarttrans.com/ has a remanufactured for $1300 (ouch) and a used for $675 +shipping...
edit://
