Who's got the most Mods on their N/A
[quote]Originally posted by Manning:
<strong>Hey Dave120, your car technically falls into the catagory of NA since it is Naturally Aspirated (as opposed to forced induction like a turbo or super charger).</strong><hr></blockquote>
Yup..which is also why it's just as hard to get more power out of..
Anyway minor mods is all that's on it:
-Koni Yellow adjustables up front, 250# Weltmeister springs, Koni yellow shocks in the rear (PO $1050)
-Transaxle from '86 Turbo w/Cooler (PO)
-968 M030 sway bars front and rear ($340)
-custom K&N intake setup (filter +$1.50 worth of PVC)
-Stainless brake lines (forget, have to look it up)
-996 17" Twist wheels w/Bridgestone S-03's ($1050 wheels +$850 rubber)
-Stainless 944S2 door sill plates ($70)
-Momo Combat shifter **** ($60)
-Alpine stereo w/12 disc changer(PO $635)
Can't think of anything else major..might be adding the computer chip soon.
My na is suspension modified,koni yellows,larger sways,Yoko avs intermediat tires.It might not make it quicker stop light to stop light,but I sure dont have to slow down for corners!!!I go thru a lot less brake pads!!Hahahahahah
<img src="graemlins/roflmao.gif" border="0" alt="[hiha]" />
My 86na...
ENGINE
89 2.7 liter
- Autothority Performance Engineering ECU Chip
- MSD 6A Capacitive Discharge Ignition w/Blaster2 Coil
- 8mm Kingsborne Plug Wires
- BERU Silverstone Spark Plugs
- K&N Air Filter
- Flow-matched Injectors
- Bursch Header (4-2-1)
- Custom 2.5" Exhaust
- Dynomax UltraFlo Bullet Muffler (mid-car, removable)
- Catco Catalytic Converter (mid-car, removable)
- Dynomax UltraFlo Oval Muffler
- AC Delete
- Linear Throttle Cam
SUSPENSION
Front
- Koni Sport Struts
- Adjustable Ride-Height Kit
- 400# Hypercoil Springs (2.5" ID)
- Adjustable Camber/Caster Plates
- 30mm Stabilizer (968 M030)
- Custom Strengthened Steel Control Arm (retrofit)
- Strut Tower Brace
Rear
- Koni Sport Shocks
- 30mm Sway-A-Way Torsion Bars
- Racer's Edge Delrin outer, Weltmeister Poly inner Torsion Bar Bushings
- 19mm Adjustable Stabilizer (968 M030)
- Racer's Edge Delrin Stabilizer Bushings
TIRES/WHEELS
- Street - Phone Dials, 15x7, Bridgestone RE-71 in 225/50-15
- Race1 - Cookie Cutters, 15x7, Hoosier A3S03, 225/45/15
- Race2 - Gotti 3-piece, 16x7/8, Kumho Victoracer V700, 225/50-16 & 245/45-16
- 930 wheel studs and spacers
BRAKES
- PBR Metal Master Pads
- SS Brake Lines
- Ate Blue/Gold Fluid
EXTERIOR
- 2.5" ABS spoiler lip added to front air dam
INTERIOR
- Sparco Evo2 Seats - Sparco sliders & side mounts
- Sparco Competition Harnesses - 6 point
- Sparco 383 Competition Steering Wheel - 330mm
- Custom Weld-in Roll Bar
- IO Port Seat-Back Brace
- IO Port Camera Mount
- Completely Stripped (except dash, center console, partial door panels)
FLUIDS
- Engine - Redline Synthetic 10W30
- Transaxle - Redline Synthetic 75W90NS
- Cooling - Redline Water Wetter + 50/50 mix
- Power Steering - Redline Synthetic PS Fluid
- CV's/Bearings - Swepco 101 Moly
ENGINE
89 2.7 liter
- K&N Air Filter
- AC Delete
SUSPENSION
Front
- Koni Sport Struts
- Strut Tower Brace
Rear
- Koni Sport Shocks
TIRES/WHEELS
BRAKES
- SS Brake Lines
EXTERIOR
INTERIOR
FLUIDS
[quote]Originally posted by Paul C 944:
<strong>Skip, can you show a photo of the 2.5" ABS spoiler lip added to front air dam ?
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> </strong><hr></blockquote>
Sure...
![](http://home.att.net/~projekt944/images/skip_dyno_1.jpg)
It would be 3 or more inches, but my driveway does not permit. Works great at keeping cones from going under the car... oops, am I not supposed to hit them.
It's black ABS plastic cut from sheets secured from Boeing surplus (very cool place). Uses aluminum screws with shaft nuts to secure. Very ghetto - not for cars concerned with looks. Most of the folks around here use a Lexan lower spoiler painted to match the car color (paint inside, prevents chipping). I break it too often to spend so much time, money, and effort.
How can you tell a true autocrosser at driver's education events? He takes out the track-out cones and worries only about that damn 2-second penalty.
S
Sure...
S
[quote]Originally posted by Skip:
<strong>
[snip]
SUSPENSION
Front
- Koni Sport Struts
- Strut Tower Brace
Rear
- Koni Sport Shocks
Skip
How are the 400# springs controlled by the Koni's. Can the koni yellows still keep up.
Heard a friend say the Koni's were maxed out with 450's... Thinking about these (400,450,500) for my 944-spec Race car and of course the rear bars (30 to 33mm) to match.
<strong>
[snip]
SUSPENSION
Front
- Koni Sport Struts
- Strut Tower Brace
Rear
- Koni Sport Shocks
Skip
They've been perfect for me - but, you're correct... 400-450# front spring is the most you want to go before a custom valve setup is recommended. Alternatively, the custom valved M030 units we do are good for up 600-650#. Anything higher, or other special requirements and you're looking at custom 28-series racing units.
400 with 30, or 450 with 31 seem to be the popular choice. My car's pretty light, so I'm sticking with my setup for a while. With a full interior, and no other attempts at lightening, I'd opt for the extra 50# and 1mm.
Wow This board works fast!
Thanks Skip <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
I am think about these for my 944 Spec car. I am thinking the weight will be down in the 2450 lbs range. Figured I can't go too stiff on a race car, at least in these spring ranges (1000# is another mater). Figure the limit will be the koni's and the $$$ it takes to get them. Still not sure EXACTLY what I want to go with, but this is great bit of information.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Check the sig.
Upcoming mods within 2 months are:
-Bursch Headers
-Dynomax HighFlo Cat
-MSD 6A Ignition
-8mm Paragon Ignition Wires
-MSD BLaster 2 Coil
Upcoming motor rebuild for the car will feature:
-2.7 stroker (finally decided to go with it)
-.475" John Millege Cam
-Port matched head and polished
-5 angle valve job and .0060 head shave
-Raceware studs
- and of course the cheap affordable Vertex Rebuild Kit!!
I am hoping to make at the least 10.6:1 compression.
Upcoming Suspension:
-Koni Oranges
-H&R 220lb springs
-Weltmeister upgraded bushings
-Weltmeister Swaybars
Upcoming Internals:
-silverface gauges
-Safeguard Systems roll bar
-4 point safety harness on both driver and passenger seats
AND MORE DECALS!!!!
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
-Bursch Headers
-MSD 6A Ignition
-MSD BLaster 2 Coil
-Raceware studs
-Koni Oranges
-H&R 220lb springs
Upcoming Internals:
-silverface gauges
AND MORE DECALS!!!!
<strong>I saw a Mod leaning on my car once. When I yelled at him he rode off on his Vespa.
<img src="graemlins/roflmao.gif" border="0" alt="[hiha]" /> <img src="graemlins/roflmao.gif" border="0" alt="[hiha]" /> <img src="graemlins/roflmao.gif" border="0" alt="[hiha]" />
I'm sure a few people are scratching their heads at your comment, but that's gotta be one of the funnier things I've read on rennlist. You slay me.
My '86 n/a based 944:
Exterior
-HID H4 high/low beam headlamps
-Hella Micro Xenon HID driving lamps
-Hella Micro fog lamps
-Euro Rear valance
-Euro sideskirts
-Nissan 300zx turbo hood scoop
-Kinesis 18" supercups
Interior
-Autometer Air/Fuel meter gauge
-Autometer Boost gauge
-Autometer EGT gauge
-Autometer Fuel pressure gauge
-Apexi AVC-R boost controller, now serving as a fancy boost gauge
-J&S knock sensor monitor
-Apexi engine timer/af/volt meter
-Momo Tornado Steering wheel
-Razo shift ****
-Pioneer DEH-P1R cd deck
-Alpine MRV-1507 2channel amp
-2x Alpine MRV-F407 4channel amps
-Aurasound Bass Shaker amp
-Clarion 4x6 component
-Alpine 5 1/4 component
-Alpine 6 1/2 coaxial
-Aurasound bass shakers
-Alpine 12" Type-R subwoofers
-Alumapro 5farad capacitor
-Pioneer 12disc changer
-secondary battery
-BK fire extingusher mount w/1LB bottle
Suspension
-rebuilt control arms
-'86 951 brake calipers/spindles/hubs
-'86 951 KVR Cross drilled rotors
-'86 951 Koni shocks
-Performance Products 220LB springs
-'89 951 25.5mm torsion bars
-Front and rear Weltmeister sway bars
-Racing Dynamics strut tower bar
-Racer's Edge Adjustable camber plates
-H&R 21mm spacers front
Engine
-Speedforce Racing Stage 2 Supercharger kit @15psi, Procharger P1SC
-2x Greddy Type-S BOV
-993 MAF
-Spearco Front mounted intercooler
-MSDS Headers
-Custom Stainless 3" exhaust from the headers
-Aurora Inductive ignition system
-Aurora 8.5mm ignition wires
-Technodyne Racing Rebuilt/ported/o-ringed head
-Factory 1st oversized 951 pistons
-ERL MF2 additional injector controller
-2x RC engineering 42LB additional injectors
-4x Siemens 55LB injectors
-Direct-port Nitrous Oxide Systems 80-shot
-2x 10LB NOS bottles w/ bottle heaters and remote bottle openers
-J&S Safeguard Engine knock elimator/sensor
-Speedforce Racing custom chip
-2x 4wire O2 sensors
Exterior
-Euro Rear valance
-Euro sideskirts
Interior
-Razo shift ****
-secondary battery
Suspension
Engine
-993 MAF
-MSDS Headers
[quote]Originally posted by marksportcts:
<strong>My '86 n/a based 944:
Exterior
-Euro Rear valance
-Euro sideskirts
Interior
-Razo shift ****
-secondary battery
Suspension
Engine
-993 MAF
-MSDS Headers
-2x 4wire O2 sensors</strong><hr></blockquote>
WOW. Let's see some photos of that engine bay. And have you been on a dyno yet?
Tifo
Exterior
-Euro Rear valance
-Euro sideskirts
Interior
-Razo shift ****
-secondary battery
Suspension
Engine
-993 MAF
-MSDS Headers
Tifo
No pics yet, some of those parts I am put in right now. I believe that I am about half way in terms of the mods I want on that car. I am not so worried on weight as this is purely a street car.
