2 Mysteries in early 944
Any idea what this hole is in the passenger side footwell ? It goes to outside air so I'm planning on plugging it.
Found this relay behind the cluster, no wires disconnected near it.
Any help or guesses is appreciated
The relay looks like a flasher relay? If you can read off the numbers for the terminals, it may help decode its function. I see a 15 and 31. Some circuit numbers are fairly unique.
The relay is a tall one, that limits the search... The car is an early. That also limits the search. The early AC relay is a 6 pin relay and tall, so that's not it. The mulitfunction relays are short and 4 pin, this one is tall. Dunno on this one...
