Ugh...Cold Idle Surging...
Old 03-20-2017, 02:20 PM
V2Rocket
Rainman
V2Rocket's Avatar
surging/fluctuating often idle valve or O2 sensor faulty.
Old 03-20-2017, 03:28 PM
Crazy Eddie
Crazy Eddie's Avatar
Originally Posted by Ashman
Resurrecting this thread. Did anyone here actually come up with a definitive answer for the idle surge at startup problem?
I'm having this same exact issue with my N.A. 1986 944. I don't remember this happening until it had been sitting for a while this winter. Now, when I start it up it almost dies, then surges back to life over and over until I rev it up a bit for a couple of minutes.
I guess I'll start with the easiest solution first - new temp sensor and go from there?
Well I finally was able to figure out that it was the KLR box
I don't believe there is one in a normally aspirated engine like yours ...
The solder joints were loose and had to be re-soldered
Tom M'Guinn to the rescue !!!
Regards
Ed
Old 03-20-2017, 06:30 PM
Ashman
Ashman's Avatar
Well, just ordered an o2 sensor and a temp sensor, so hopefully one of those two will fix the problem.
If not, then it's on to other more complicated possible reasons for the problem...
Thanks for the help.
Old 03-20-2017, 06:49 PM
Ashman
Ashman's Avatar
Originally Posted by Crazy Eddie
...I don't believe there is [a KLR] in a normally aspirated engine like yours ...
Thanks, Eddie. Yep. No knock regulator on my N.A. I'll just have to search elsewhere.
Beautiful car, BTW.
Old 03-20-2017, 10:11 PM
snb13
snb13's Avatar
What mods, if any, have been done?
Old 03-21-2017, 01:12 PM
Ashman
Ashman's Avatar
None on my car, other than a battery disconnect switch. I'm trying to keep it as stock as possible.
Old 03-21-2017, 05:15 PM
peanut
peanut's Avatar
after having the same issue the past few weeks my conclusion is leaking injector/s and possibly the fuel pressure regulator ( FPR) also.
When the engine receives a rich mixture at idle when cold, the ECU corrects the rich mixture by increasing the air flow through the Idle air control valve but the correction is usually an overcorrectlon so the ECU reduces the extra airflow through the idle air control valve which sets up a constant fluctuating idle.
The additional fuel that is causing the over rich idle mixture is probably due to either a leaking FPR leaking fuel into the vacuum system or leaking fuel injectors.
If you start the car and pull of the vacuum pipe from the FPR and damper you can check to see if either are leaking fuel into the vacuum system. If they are ok then a fuel pressure and leakdown test should narrow down the cause of the issue
Quick Reply: Ugh...Cold Idle Surging...
