Gutting the Doors
Gutting the Doors
I am in the process of gutting the doors on my car for installation of a cage with NASCAR door bar. I have the door panels and the door lock mechanism off. How do I remove the window motor and glass?
TIA
TIA
roll window halfway down, yank up firmly on the glass and it just seperates from the rail. then just unbolt the regulator and slide it out one of the rear holes on the door.
Nader, You may want to take a cut off wheel and trim out around the perimeter of the door. I'm guessing that someone else will be installing the cage...the more room you give them, the better. My installer didn't have enough room and wasn't too careful about making cuts into the door. I'd leave an inch lip that you can then finish with a dull edge or plastic trim. Will you be joining us in any events in NC?
Hi Gene,
I am going to use a sawzall after I get everything out. Not sure about my schedule next year, but VIR will be as far south as I would likely get. I am thinking about Mosport as my long haul trip, but nothing firm yet. Happy New Year.
I would recommend a 4" cut-off wheel to cut the panel out of the inner door. A sawzall will be like trying to hacksaw something that is not firmly anchored down...essentially just moving the material back and forth, rather than cutting.
Here's my door gut job:
http://www.brooksbabies.com/porsche/inst11.htm
BTW, it looks like I'll have to relocate the "door opening" handle as mine is in the middle of the door.
it's not secured as in the glass is not bolted down to the regulator no. it's a rubber lining friction fitted inside a metal channel.
Windows are out, but I guess S2s are different. I had to remove the bolts that hold the power window arms to get the glass out. The bottom of the glass has two rails that the arms fit into. Once I removed the bolts, the glass was lose. Next is cutting the door panel. I really like your idea of putting a trim around the cut.
Hi Nader,
As it so happens, I just replaced my passenger side door so I needed to gut it. Here's after I pulled the window and cut the panel with a cut-off tool.
Next I relocated the door pull and then trimmed out the raw edges with the same trim that is used around the door sills. The door glass is just lying in there now as I slide it back up and pin it when I leave the car out. When racing I just pull the whole glass out for the day.
Hope to see you out at the track next year at some of the 44Cup events.
I did not leave much metal at the top of the door and therefore could not mount the door handle there. Mine is mounted to the metal bar in the middle of the door.
I unhook the regulator's sliders from the part that holds the glass. Then you can pull the glass up about 1/2 way by hand, and tilt it towards the door hinges, and it'll come clear from the rails.
Then you just unbolt the regulator and wiggle it out of the largest opening.
BTW Chris, do you leave the window rails in? I plan to cut lexan to put in the window while transporting. Meesing with the glass worries me. I also have to figure out how much of the wiring to move. I like my power mirrors
In my glass the bottom metal piece is still attached to the glass. I just drilled a hole through the door and through the bottom metal part of the window and pin through the holes to keep the glass up when paddocked.
I wouldn't have any problem with transporting with the window glass in place. When up and pinned they are locked in the door window channels. And it was cheaper than buying and cutting lexan since I already had the windows.
