968 sway bar mouting ideas?
#31
Ok, so made a mount with a head that has a 8mm hole that was bolted onto the alubars, with custom washers on both sides made to fit the slot in the bar, and a locknut in the other end.
Made new mounts that are exact the same as the stock ones but with a much shorter M8 pin in the other end.
These 2 will be attached by a uniball.
I kept the stock rubber on the sway bar, that together with the uniball will allow for the same movement as the stock setup has.
So, problem solved
just waiting for the uniballs to arrive.
Thank you all for your ideas and feedback!
![](http://speedfreak.nu/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=72047&g2_serialNumber=1)
![](http://speedfreak.nu/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=72044&g2_serialNumber=1)
While I was at it I also made a reinforce bracket for the sway bar mount to the chassie, seen these as an upgrade part on the web but was easy enough to make them yourself.
So, problem solved
#32
I agree with Oddjob in that the stock design is the most effective. The fabrication you need to out-engineer Porsche on this is risky at best. Good luck with it though!
#33
My old car is a Skyline R32 GT-R tuned to about 550 hp with uprated suspension,
brakes, etc etc and that is not a very reliable car to use as a daily beater anymore but well maintained it is a reliable track, and occasional street, car. My Porsche will be a track only car but it will be street legal for now to make transportation to and from the tracks easier, need to get a license to hall a trailer with the car on :/
So basically I can go all the way with this one... and I will.
#36
#39
You cant mount the swaybar ends to the strut/spring perch - the macpherson struts pivot when the wheels are turned.
Ford do it on the 2005 Mustang.
Here's a pic, complete with THK link ***** (not standard).
We use THK link ***** at work, in far more severe environments than auto use.
Attachment 412214
#40
THK Link ***** - good product for this app.
http://www.thk.com/eng/products/clas...all/index.html
Mike
Mike
