Rear Rotor Play
Rear Rotor Play
Went to grind of 1/16" out of section of my rear wheel well, slight rub on the drivers side w/ 255-40-17, and upon re-installing tire/rim I noticed a slight amount of up/down play at the rotor. I'm not getting any bearing noise and the axle bolts all looked fine. Could it be that large nut at the end of the axle be my problem? I have read before that guys doing auto-x have had them loosen up. I haven't hit the Haynes yet to see how it all bolts up but I'm assuming that nut pulls everything tight.
nh3
nh3
Is there a difference in nut size between early and late model? I now that the steel arms used a cotter pin and I have aluminum which has no pin.
nh3
nh3
The 1-1/4" nut on the stub axle was loose by about a 1/4 turn. It tightened up the play I was getting but being that the bearing wasn't properley seated in the race for a few miles....No noises but something for the winter maintenance list.
nh3
nh3
