help! stripped hex's cant remove seat.
Old 12-10-2009, 09:19 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
Originally Posted by ritzblitz
Try using a torx first. It usually works. If that doesnt work then just do the dremel slot screwdriver deal.
Exactly how I did it. Broke an easy out on the allen bolt because it's really hard steel. Took a slightly larger Torx and popped it in with a hammer. Slowly increasing my pressure on the Torx bit I was able to get the allen bolt out. Good luck.
Oh yeah, don't forget to 'wake up' the bolt with a few pops with the hammer. You don't have to kill it and warp your floors. Just tap that bad boy.
Old 12-11-2009, 10:03 PM
djpotential
djpotential's Avatar
OK, So what size voltage dremel do i need?
Old 12-11-2009, 10:56 PM
hockeydude
hockeydude's Avatar
i just used a regular handheld dremel and one of the brown cutoff wheels to make my groove.
here's the one that i use http://www.google.com/products/catal...wBA#ps-sellers
and you can even see the little brown cutoff wheel in the pic. and it's like $3 for a pack of 20 extra wheels.... you will break some, so be sure to wear eye protection!
Old 12-11-2009, 10:57 PM
hockeydude
hockeydude's Avatar
nopw that i look at it, that's the single speed version... mine is the multi-speed, but i always turn it on high, so i guess that it wouldn't matter!
Quick Reply: help! stripped hex's cant remove seat.
