Who sells metric bolts?
Old 03-12-2003, 08:39 PM
kasturbo
kasturbo's Avatar
Post Who sells metric bolts?
I'm looking for lower shock bolts that are stronger then the standard 8.8 class that came on our cars. Anyone have a good source? I've tried all of the local hardware and part stores.
Old 03-12-2003, 09:55 PM
cruise98
cruise98's Avatar
Post
Kevin:
Have you tried a motorcycle shop? There is probably a fastener supply shop in town that can get what you want. Metrics can be a real pain to track down. Fastenal can order whatever you want, but I am not sure if they are in Hilliard.
Old 03-12-2003, 10:20 PM
Perry 951
Perry 951's Avatar
Post
Kevin -
Try Jegs. They had a good selection the last time I was there.
Old 03-12-2003, 11:11 PM
kasturbo
kasturbo's Avatar
Post
Thanks guys, I didn't think about Jegs. I wonder if ARP makes what I'm looking for.
Old 03-13-2003, 12:17 AM
Perry 951
Perry 951's Avatar
Post
ARP = $$$$
I have rod bolts you would think are solid gold!
Old 03-13-2003, 12:21 AM
kasturbo
kasturbo's Avatar
Post
I wouldn't expect anything less out of that motor you built.
Old 03-13-2003, 12:25 AM
Perry 951
Perry 951's Avatar
Post
What are you looking for? I have a place down the street from my home that has gobs of metric grade 12 fasteners. Most are allen head, but I can get normal hex tops if needed. (I prefer the allen heads for smaller bolts)
Old 03-13-2003, 09:51 AM
kasturbo
kasturbo's Avatar
Post
I need a 14mx90m hex or allen head. It needs to have the fine 1.5 thread pattern and at least a 10.9 strength class. These are for the lower shock bolts in the rear. I'm upgrading to coil overs and removing the torsion bars. So I would be more comfortable with a little stronger bolt holding the weight of the car. You'd be the man if you could find it. I've looked every where.
Old 03-13-2003, 11:04 AM
art
art's Avatar
Post
I bought all of the new bolts for my trans rebuild from Mcmaster-Carr which is an industrial supply house. They have most things in all grades. They have a website, but it helps to have the catalog for part#'s
Art
Old 03-13-2003, 11:07 AM
Michael Weinstein
Michael Weinstein's Avatar
Smile
Ace Hardware and Lowe's have grade 8 hardware. Paragon Products has a kit containing a good assortment of the typically used nuts, bolts, and washers.
Whoops, just noticed that you said stronger than grade 8.
Old 03-13-2003, 12:22 PM
kasturbo
kasturbo's Avatar
Post
I'm pulling my hair out here. Everyone has a bolt on each side of what I need but not the actual size that I need. I found a place that will make the bolt for $95.
Old 03-13-2003, 12:57 PM
Dave E
Dave E's Avatar
Post
Did you consider the Racer's edge adapter? Pricey but specific for what you're doing.
Old 03-13-2003, 12:59 PM
Perry 951
Perry 951's Avatar
Post
Kevin -
I'll run down the street and see if they have what you need.
Old 03-13-2003, 01:01 PM
kasturbo
kasturbo's Avatar
Post
Yes I have considered that. The problem there being that those are a 1/2" adapters and the hole is 14mm. I may just have TrueChoice put a 1/2" bearing back in the shock and go the adapter route. True Choice is also talking about building me an adapter.
Old 03-13-2003, 02:29 PM
Perry 951
Perry 951's Avatar
Post
Kevin -
No dice on the bolts. The biggest they had in 1.5 thread was a M14X60.
Looks like mail order is in your future. Good luck. BTW... step it up to grade 12. Better safe than sorry.
Quick Reply: Who sells metric bolts?
