Throttle Respone Cam
Old 03-27-2003, 05:14 PM
Chad S
Chad S's Avatar
Post Throttle Respone Cam
I just ordered a Throttle Response Cam and was wondering what it in tailed to install it.
Any one out there install one.
Old 03-27-2003, 05:17 PM
schnellfahrer
schnellfahrer's Avatar
Post
Remove one nut - remove old throttle cam - install new throttle cam - reattach one nut.
Even I could do it.
Old 03-27-2003, 05:24 PM
Chad S
Chad S's Avatar
Post
That easy? I thought you may have to cut the throttle cable.
Cool!
Old 03-27-2003, 05:30 PM
Tom R.
Tom R.'s Avatar
Post
that cam throws you into modified in metronypca.
nixwiz
nixwiz's Avatar
Post
You definitely need to take the slack out of the throttle cable and possibly adjust the stop under your accelerator pedal. Which one did you order and from where....it should include instructions. If not, I could fax you mine.
Old 03-27-2003, 05:33 PM
Chad S
Chad S's Avatar
Post
I got it from Performance Products.
<a href="http://www.performanceproducts.com/ProductPage.aspx?productname=Throttle+Response+Cam&productid=106212&prod ucttype=20" target="_blank">http://www.performanceproducts.com/ProductPage.aspx?productname=Throttle+Response+Cam&productid=106212&prod ucttype=20</a>
Old 03-27-2003, 05:40 PM
Jfrahm
Jfrahm's Avatar
Post
I don't get these, can't you just move your foot farther or faster? I never seem to have any trouble finding WOT :-)
-Joel.
Ben Plaisted
Ben Plaisted's Avatar
Post
Its really simple, I just had to adjust the throttle cable a little bit after I put it on and that was it. like schnellfahrer said "one nut off, one nut on" simple as that. good luck and enjoy.
Old 03-27-2003, 05:53 PM
Dan Gallagher
Dan Gallagher's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Tom R.:
<strong>that cam throws you into modified in metronypca.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">??
Old 03-27-2003, 06:05 PM
Mike S
Mike S's Avatar
Post
Really simple just check the stop under the pedal otherwise you'll stretch your cable or break it when you stomp the pedal down. I had to adjust mine about a 1/4" or so.
These don't add horsepower, but they do make the response a bit better....I like it on a 944, but onthe turbo its not so hot.
Old 03-27-2003, 07:32 PM
Joe944
Joe944's Avatar
Post
Hey I got one from Paragon and when I went to put it on just for looks ( intake is off right now) it wouldnt go on right all the way? It got stuck, I think the hole is a little too small =/ anyone else have these problems?
Old 03-27-2003, 07:33 PM
Joe944
Joe944's Avatar
Post
Old 03-28-2003, 04:13 PM
gleamingred944
gleamingred944's Avatar
Post
What this gizmo does is to change the pedal response from log to linear. With the Porsche system, each time you put your foot down a bit more, you get a bit more power. With the circular cams, you get a lot of power at the beginning, then almost none is left at the end.
Not only that, but (HERESY!) if you use the cruise control on 500km throughway drives, the cruise has problems at low power and tends to hunt.
I took mine out and put back the Porsche original. Like it much better.
Old 03-28-2003, 04:37 PM
pete944
pete944's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by gleamingred944:
I took mine out and put back the Porsche original. Like it much better.[/QB]</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I've got one and my cruise control is steady as a rock. Personally, I like the throttle cam. As cheap as they are it's worth trying. If you don't like it, someone here will buy it.
Old 03-28-2003, 04:42 PM
Chad S
Chad S's Avatar
Post
Thanks for all of the review and tips.
Quick Reply: Throttle Respone Cam
