944 na calipers maintenace
I have 88 944S with 944 brake calipers.
I use the car weekend during summer and some other days also but car stands most of the year.
It is not good on brakes as calipers rust even if car is driven daily. I use Hawk blue pads and get uneven wear of pads. One at the side of the piston wears two times faster. It seems that brake disk has some uneven wear on outer side. Some pretty deep grooves.
I plan to install brake cooling ducts. Right now brakes are stock.
I have some questions for you all.
1. What I can do against rust? How to clean and keep it to minimal. I do not like the painting as paint seems to burn off and you cannot paint sliding surfaces.
2. How you maintain the calipers that do not get used often? I know that I should install copper grease to sliding surfaces but how often?
3. For track use how should brake disk dust shield look like. I know that I should direct cooling air to the center of the disk and keep it there. How big should be dust shield? Like original or with smaller radius?
4. Some suggestions how to setup and maintain 944 brakes when used mainly on track?
I have some brake dust shields off a 944 Turbo (87) that you could try. These have a big hole cut from the factory where the air is ducted in. Hawk's are going to rust because they have high metal content, not much you can do about that. Sounds like the calipers need to be rebuilt. They have these little nylon sliders that have to work just right.
I rebuilt my calipers (they worked fine before but looked like hell). I disassembled them, including removing the piston assembly. That leaves two "boat anchors" which can be easily cleaned. I found that a bath in Muriatic Acid made them spotless. I then painted them with a high-temp spray paint and re-assembled them. Pad wear has been fine. While I was there, I replaced the rubber "boots" on the pistons.
These are super-simple brakes, and it was fun and informative to take them apart. Below is the end result of my work (includes new rotors and SS brake lines. Never thought a single piston floating caliper setup could look good!
![](http://i124.photobucket.com/albums/p11/gcirillo/Car%20Junk/2009-06RyansCamera195.jpg?t=1259622108)
Mine will seat in the garage sometime six months at the time, the reason our long & terrible winter & tonne of salt on the on the road,I'll start the car twice a month & then drive down my driveway applying the brakes at least a dozen time in order to keep the calipers & rotors alive,what I use on them to keep the rust away was a fire red (Super -Anti- Rust weather shield paint) made by Fedecor they are the O.E calipers & still running strong since 83,the pic is not that good but will give you an idea what they look like ,hope it does help.
Potomac-Greg, do you have some kind of cooling setup there?
What is that thing behind the brake disk?
I have rebuilt those calipers before. I painted them but paint burned off.
I will rebuild with new seals.
![](http://i124.photobucket.com/albums/p11/gcirillo/VIR%20NASA%202009/2009-10-10VIRwithNASA095.jpg?t=1259697546)
Tere Joonas,
for rust protection you can for example yellow or black passive your caliper parts. Then add powder coating to most visible parts. Total cost will be about 40-50€ (at least here on the other side of the gulf)
hey guys, whats the deal with the 2 little clearish plastic pieces that come with the caliper reseal kit? im not sure if it comes with all of them but the one at 944online has them in the picture if you dont know what im talking about.
http://944online.com/cgi-bin/ASI_Sto...akesystem-9442
none of the calipers i have ever taken apart have ever had any little plastic parts in them?
Just a car guy
http://www.g2usa.com/Merchant2/merch...roduct_Code=G2
Have found it to be rather robust. I have also used the so-called caliper paint from Dupli-color. That paint is adequate, though not as robust as the G2 paint system. What's worse - the Dupli-color paint will come off when exposed to various chemicals - especially brake-clean. Any standard paint will burn off quickly. Even high-temp paints have their limitations.
