HELP!
HELP!
again and everything was working fine? Is my clutch a goner? I recently had the master cylinder replaced, could it not be adjusted right?thanks for any input.
Again what?
When my clutch went (rubber-centered disk) at about 80k miles on it, I could roll the car with it in gear. Try to push your car forwards and backwards with it in 3rd gear. If it doesnt move, your clutch should be fine...or at least still working. As far as your master cylinder (brake master?) the clutch SLAVE cylinder may need to be checked.
