Steering Wheel
Toronto,
Here is a quick run-through:
Tools: 24 MM socket w/extension, extendable magnet(not neccesary, but it makes things easier.)
Place thumbs in center of horn pad and wrap fingers around the sides of pad, pry out with your fingers, untill pad pops off. Unhook horn wire, put pad aside, use 24MM socket to remove retaining nut, use magnet to retreive washer(s). Pull wheel towards you. Voila* you are done.
*Voila--a French word meaning "wow, would you look at that"
