Ground wire between PS rack and crossmember
The rebuilt PS rack I got from autozone does not have a mounting point for the high pressure line mounting clamp, which is where the ground wire would also attach coming from the crossmember. Should I bother reattaching this ground wire? Not knowing exactly why this is there, I am having difficulty in evaluating alternative grounding points!
Thanks for the heads up on that. I would not have guessed that those circuits would require a crossmember to ps rack ground, so I am glad I asked. Haven't reattached the battery yet, but will make sure to keep an eye out for random electrical gremlins after I find a suitable alternative grounding point. Any suggestions are welcome. Maybe the view port on the underside of the rack?
