Headlight Mods
I have the GT racing fixed light conversion and a Fiberwerks nose, I'll be running dual driving lights instead of those huge square things. How can I alter the factory wiring so the lowbeams and the fogs stay on with the highbeams? TIA!
i did my own conversion and had the same problem. so i just hooked both of them up and the same time and i don't have high beams. if you find a way to do it right i would like to know.
This is a long post from awhile back but I think you could modify this to work for you. A fellow lister rewired his euro driving/foglights to work independently or all together with low or highbeams while still using the headlight stalk. HTH
Good Luck,
Dsalillas
Good Luck,
Dsalillas
Good Luck,
Dsalillas
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=010449#000000" target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=010449#000000</a>
Good Luck,
Dsalillas
