Simple Exhaust Question - 944 NA
Hi,
Thanks, as always, for the input. Is the following statement accurate?
After searching posts on exhausts, it looks like there is no noticible gain from changing the pipe to a larger diameter, or replacing the muffler with a higher flowing one. It seams that the only worthwhile gain lies with the cat.
I do not wish to drive on the street without the cat. As a note of interest, I talked to Steve Wong a few years ago, and he said that replacing the cat on a Carrera 3.2 with a Dansk Sport cat (very expensive), that is constructed with a metal substrate core (as apposed to a ceramic core), did not change the power output when compared to a premuffler.
that's pretty much what most ppl agree on.
bigger doesn't equate to better when it comes to NA exhaust. running a 3" exhaust pipe will only cool and slow down the exhaust gases, reducing scavenging effect and exhaust gas velocity.
I've got two cat-back systems, one with a full muffler and one with a resonator. Both bolt on after the cat. With the more open system, I do see more top end power/speed on track. It's minor, but noticeable. So the cat might be a restriction, but so is the muffler.
My view is that I'll keep the cat on even though my car has "historic" plates and is not subject to inspection. I'm not a tree hugger, but I do want to be responsible to Mother Earth.
For whatever it is worth....I agree about keeping the cat. It does not seem very responsible to omit the cat for a gain that may not be noticeable for street use. Also, I doubt that I would ever have a better "track day" because of a deleted cat.
James
James
Hi,
my car would NOT run on 91! it would stutter and do all kinds of weird things
mixed some 87 to make it close to 50/50 mix (3-4 gallons of 91 and added about 4-5 gallons of 87) and the car started running perfect again
from that point on I stuck with 89 and happy
everything about the 944 is geared towards low end torque. If you change the exhaust and leave the cam stock, you won't see any gains. If you change the cam and leave the exhaust stock, you'll see a little but not as much as if you changed both.
Also this is the reason why putting in a test pipe doesn't do anything for power. The exhaust still has to go through this
