Changing Oil Pan Gasket
I have read in previous posts that you need to support the engine in order to change this. I was wondering if anyone had any instructions for the best way to build a brace to support it from the top.
Check the pix at the bottom of this page:
<a href="http://64.226.197.185/Paragon/Tech/944_rod_bearing_replacement.htm" target="_blank">http://64.226.197.185/Paragon/Tech/944_rod_bearing_replacement.htm</a>
