Outer window seal Replacement
Has anyone replaced the outer rubber window seals ? Part numbers are 477837470A and 477837469A. Do I have to remove the door panel to do these ?
Rainman
if its the window scrapers no you dont have to remove the window, just lower them all the way. it helps to have a metal putty knife to pry the little metal clips open a bit to get the seal in
