finally... painted engine bay pics
#31
thanks guys, coming from you guys especially makes me feel pretty good
also, does anyone happen to have one of these sitting around? obviously i dont expect anyone to have a painted one but i need one none the less...
#33
at first i was like.... ಠ_ಠ
but then i LOL'd
i really expected that to be harder... i still have to feed the lighting harness plugs in there... so maybe i should just be quiet...
anyway guys i need to know what this plug goes to.... its on the section of the harness that goes along the firewall to the battery... the only other things in the same section of harness are the suplimental positive leads from the battery. i plan on deleting ths whole section of the harness and i need to know if i need to keep this plug for anything...
but then i LOL'd
#34
ah i think it might be for the cruise control? i dont have that anymore so this whole section of the harness is going bye bye. well not really... just going somewhere else
#36
nope... none of that fancy stuff for this lil ol' NA
this was seriously not fun... at all
but i got it all in there
anyone know what the white plug on the end of the red and blue wires is for? i dont remember any of this...
#39
#40
ok so things i need and am looking for...
that broken headlight pivot point thing at the top of this page.
front brake pistons... i dont need the whole calipers... just the pistons... but if someone has a set of good front NA brakes sitting around i need some.
let me know thanks
let me know thanks
#44
last shot of the engine on the ground before sliding it under the car...
carefully lifting into position... making sure to not scratch anything...
got hung up on the drive shaft not wanting to go through the clutch...
the reason it was getting up is because i dont have a clutch alignment tool... i just eyeballed it... BUT to the alignment tool i say PSHAW and just go ahead and release the clutch with a vice on the release lever
look ma... no wires
and then a quick cleaning of the garage...
and im done for the night
so other than the alternator, some fuel and brake lines, and an air filter... this is ALL that will be in the engine bay
comments welcome
look ma... no wires
comments welcome
