How do I prep for bigger rims ?
Old 10-16-2009, 12:53 PM
WizPorsche944
WizPorsche944's Avatar
Default How do I prep for bigger rims ?
I have a good question for you guys. What all should I do with the car to prepare for larger wheels & tires ? Next spring I will be buying a set of 17" Cup II Wheels for my 944
I already have Koni struts and shocks and I plan on rebuilding the ball joints, but everything else is stock.
Old 10-16-2009, 01:08 PM
krystar
krystar's Avatar
u don't need anything at all. just that simple.
Old 10-16-2009, 01:40 PM
Van
Van's Avatar
You need bigger tires for the bigger rims... maybe those snazzy LED valve stem caps. That's about it.
Old 10-16-2009, 01:42 PM
tifosiman
tifosiman's Avatar
968 Caster Blocks for the a-arms. Even if the factory didn't already recommend it for 17" and larger wheels, its still a good idea.
Old 10-16-2009, 01:44 PM
Reimu
Reimu's Avatar
Why just rims? You can buy the entire wheel already together
Old 10-16-2009, 02:17 PM
Litespeeds
Litespeeds's Avatar
If you have a 944 NA, you will need more HP if you go with bigger rims and tires. I have tried all different combinations on my 1988 944 from the stock 15x7 Phone Dials to 16x7 and 16x8 turbo PD's, 17x7 and 17x9 Cup, 18x8 and 18x10 turbo twist, then back to 15x7 early offset PD's and my handling and acceleration is the best with this combo.
You might also consider upgrading your front brake pad to Hawk HP Plus as you will need a more agressive pad for stopping with those heavier wheels/tires.
Old 10-16-2009, 03:15 PM
MAGK944
MAGK944's Avatar
I like the 15in Fuchs and 225/50R15 tires on my 86, it just drives and accelerates so well with that combo. I have tried 944's with 16 & 17in wheels and none of them handle as well or have as much "zip", they just seem slower to accelerate, all except the S2's that is.
You will definitely feel that the car is slower with 17in, but no prep required, just get a good alignment afterward.
Old 10-16-2009, 03:44 PM
WizPorsche944
I really want Fuchs but its almost impossible on an 87
Old 10-17-2009, 12:34 AM
Portly
Portly's Avatar
I'm glad I'm not the only person who's sick of the incorrect use of the term, "rim".
Old 10-17-2009, 03:44 AM
Litespeeds
Litespeeds's Avatar
You can fit the 15x7 Fuchs on a late car as well as Cookie Cutter wheels in the size 15x7 as long as the offset is 23.3mm and you have at least negative 1.5 degrees of camber with 225/50/15 tires, otherwise you can use a 205/50/15 on the 15x7 rim and it should clear without any fender issues. For the money, the Cookie cutters are the way to go since you can pick up a nice set for around $300. The Fuchs are definitely more and most come 15x7 and 15x8 which you can not use the 15x8 no matter what as it sticks out way too far.
Old 10-17-2009, 09:36 AM
Potomac-Greg
Potomac-Greg's Avatar
But big rims go so well with big breaks. Not to mention European bumbers.
WizPorsche944
Intresting, is setting camber hard ?
Old 10-17-2009, 10:52 AM
944CS
944CS's Avatar
The car would look awesome with early offset 16x7 fuchs and 205/50/16 tires
It would also handle awesome and accelerate better than stock
but if you can't find 4 16x7 fuchs you'll be able to fine 4 15x7 fuchs
in that case run 205/50/15 tires
Old 10-17-2009, 11:17 AM
krystar
krystar's Avatar
u just turn the camber bolt. although best done with an alignment rack.
Old 10-17-2009, 03:08 PM
R.J.
R.J.'s Avatar
Especially with our 4 CLY engines...
Quick Reply: How do I prep for bigger rims ?
