my finished airbox mod
Old 08-07-2002 | 06:56 AM
Cass944's Avatar
Cass944
Post my finished airbox mod
heres the steps i took to do this. it sounds amazing. it seriously sounds like i have a freakin v12 when im at full throttle. great improvement. check it out and tell me what you think.
Old 08-07-2002 | 07:08 AM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
Thumbs up
nice crest-shaped opening. good work.
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old 08-07-2002 | 07:12 AM
Brian Wilson's Avatar
Brian Wilson
Post
Looks good.
Could someone give a rundown of the consequences of sucking in the hot air from around the engine (if any). It looks like a really logical, good idea.
Good work on the creativity.
Old 08-07-2002 | 10:20 AM
Toolmaster's Avatar
Toolmaster
Post
Ecpunk -
If you're sucking in hot air from the engine compartment, technically speaking you're not extracting the most amount of power you could from the car.
There's a fine line here though. The additional air you're ingesting could potentially offset the heat-loss, giving you a slight net gain in power.
A perfect intake would be getting ice cold air from outside the car, with little to no restriction on it.
What this gent has done is modify the airbox to function almost like a cone filter. More air, better flow. The cone filters seem to also take in a lot of hot air too, but some people notice a seat of the pants improvement.
HTH!
Old 08-07-2002 | 01:28 PM
Dave H.'s Avatar
Dave H.
Post
it's hard to get cold air since the pre-filter side of the box is the shallow side. on the vw's, the deep side of the box is the pre-filter side, plus you only drill the fender side (away from engine) of the box, where fresh cold air is coming in from around the headlight.
basically on our cars all you get is a little extra roar when you get on the gas...
Old 08-07-2002 | 03:13 PM
TonyG's Avatar
TonyG
Rennlist Junkie Forever
Post
I think the red/orange paint has got to go.
Further... why did you paint the hose? <img src="graemlins/icon107.gif" border="0" alt="[icon107]" />
Old 08-07-2002 | 03:32 PM
my944's Avatar
my944
Post
Cut Out Idea = Good
Paint = No Bueno
IMHO, If you painted the screen that you installed in the cut out red, then I think it would look much better.
Old 08-07-2002 | 03:38 PM
Manning's Avatar
Manning
Post
You know, you get a lot of airflow through the engine compartment. Here is a picture I posted a couple days ago:
The arrow on the left point to a huge opening above the radiator and to the left (in the picture) of the headlight. This opening is really big and is exclusive of the radiator, meaning it does not flow hot air from the radiator. It does however source its airflow from the same outside source as the radiator. This is the opening for the ducting to cool a 924 alternator by the way. This opening is in addition to the one in the fender from which the intake usually draws outside air.
Why do I bring this up? To point out that a ton of cool outside air flows into the area around the airbox or cone filter. This air flushes the hot air out of the engine compartment as well as feeds the motor. Sitting still at idle obviously a lot of hot air fills that area, but once you get moving it gets flushed out. There is not a lot of excessively hot air in there when you are moving.
I may have to do some experiments with a thermometer to prove my point. I'll keep you all up to date if I do.
Old 08-07-2002 | 04:17 PM
*Rothmans*'s Avatar
*Rothmans*
Talking
My bet is that the factory did it right and there are no horsepower gains.
This modification is technically "cupping" the air box, except it's just ONE BIG HOLE, but it serves the same purpose.
I think cone filters look cool, but do not draw COOL air, at least not until you are moving fast enough to vent hot air out.
Esthetically, a red air box, with a yellow screen rimmed by the black would remind me of a cloissone
(sp.) crest and stick more with this guys nice looking burgundy paint.
I think until you add a mass air kit to your car, that barn door will be the one constant air inlet restriction, nevermind the temperature!
And by the way, in the garbage pail is a tube - isn't that the one that attaches to the tube to draw cool air from the fender well to the alternator ?????????
Great idea and outstanding job on your cloissone cupped box !!!!!!!!
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Old 08-07-2002 | 07:34 PM
Eric D's Avatar
Eric D
Post
Nice creativity with the crest shape. What is that screen made of though. That looks like the stuff on the backs of my dining room chairs, I think it is called decorative caning.
Old 08-07-2002 | 07:45 PM
Kool's Avatar
Kool
Part of the IN Crowd
Post
Another advantage to the hole is that now you don't have to take the airbox apart to see whether or not your filter needs changing. Good job.
Old 08-07-2002 | 09:20 PM
Lemon Yellow 87 n/a's Avatar
Lemon Yellow 87 n/a
Post
Have a similar mod, sounds amazing, and throttle responce is up a bit (combine with a round throttle cam and you have some pretty descent responce, I was very pleased)...
Old 08-07-2002 | 09:21 PM
Dave H.'s Avatar
Dave H.
Exclamation
except that it'll need changing sooner
Old 08-08-2002 | 04:31 AM
Skip's Avatar
Skip
Post
The "Lemon" is back... was that you on I-5 North in Washington around Everett at ~2pm today? Not too many Lemon Yeller cars 'round here
Skip
Old 08-08-2002 | 05:48 AM
Cass944's Avatar
Cass944
Post
i dont knwo if your asking me but nope i live in WI, never been out west. but i'd like to
Quick Reply: my finished airbox mod
