Mcpherson uppermounting nuts.
The four bolts to attach the strut to frame are called uppermounting nuts. I broke all of them loose at around 30ft\lbs and it tells me to bolt them or tighten them at 57ft\lbs is this correct? I personaly think they will snap off.
straight from the paragon site:
Torques (ft-lbs): Strut cap = ~110, Strut nut = 57, Strut to hub = 74, Strut to body = 18
the strut nut is the center bolt and the strut to body bolts are the four spaced around the center bolt
