quick timing belt question
Old 09-26-2009, 04:42 PM
  #31
Reimu
Reimu's Avatar
Since we're on the topic of timing belts...
Do they often just strip without warning or is it common for something to seize and rip out the teeth?
Mine ripped out a bunch at around 4krpm with no warning on a 3 year old belt, just wanting to diagnose.
Old 09-26-2009, 06:47 PM
  #32
944meister
944meister's Avatar
Originally Posted by CameronKame
Mine ripped out a bunch at around 4krpm with no warning on a 3 year old belt.
and there's your problem, replace belts every 30k(early)-45k(late) miles or two years, wich ever comes first.
Old 09-26-2009, 08:00 PM
  #33
944Ross
944Ross's Avatar
I've got two belts removed from cars with documentation showing them to be 6 - 8 years old, 20-25k miles and they have absolutely no evidence of cracking or wear. Would I use them? Hell no. But like I said earlier, I'm convinced failures like yours are most often tensioner or water pump problems that ruin the belt.
Old 09-26-2009, 08:16 PM
  #34
roman944
roman944's Avatar
well, I am pretty sure that my failure was caused by the balance shaft belt
my car still ran fine, I wish I had known what to check for - I would have checked the belts first thing and taken out the balance shaft belt - would have been MUCH cheaper and faster then what I ended up with
oh well, live and learn
rebuilding the head here at home - what parts would be needed? new valves obviously, springs, guides? what can be done to the head itself as far as machine work (nothing extreme)?
Old 09-26-2009, 08:19 PM
  #35
jderimig
jderimig's Avatar
What about age of the belts on the shelf?
Old 09-26-2009, 10:22 PM
  #36
Reimu
Reimu's Avatar
Yeah that's what I was thinking. Guess I'll just replace the pump/thermostat, wouldn't hurt to have a good one in.
Quick Reply: quick timing belt question
