'LiL Mule's thread
I picked up a pair of adapters off ebay for ~120 IIRC.
I don't have any other pics as of yet. I didn't follow through completely getting the front hubs done.
At this point I can only put the rears on. After I get the engine all tuned in... that, and finishing the paint will be my next priority.
I don't think you could do it with a late offset. The spacer/adapters are ~2" thick. That would push the tire too far out.
When I first installed the Tial It had a 1 Bar spring, boost rose very very quickly, I'm sure I was seeing over 10 PSI under 2500 RPM. I have since installed a .6 Bar spring to get better boost control. I must say 13 PSI was awesome but my Safeguard lit up like a Christmas tree (knock), that kind of boost would require lots of boost retard. What PSI did you run with the SC?
18 psi was the max with the 2" pulley. I used E85 and had a methanol spray as well.
I am curious about the lowest point. Maybe soon, you could watch in 4th gear and see when you hit 5 psi on a gradual drive??
If you are getting 10 psi below 2500 rpm it must be a blast to drive. Personally other than the SC setup I have not had a great feeling driving around town with these cars.
However, I have been running big turbos too so that is probably why. I will say though that there is something to be said regarding the rush of 25 psi hitting hard, even if it is a little laggy .
Sid,
When you get it running I know where there's a ferrari owner waiting for his doors to be blown off by a 944 - again! His shop does good paint work on porsches.
friday is an open track day at high plains, i will probably take the M3 there.
1 Post
Hey Sid,
Looks very similar to what im doing to my car. How did you end up mounting the 951 IC on the early car? I had to do a lot of cutting/grinding/welding, and at this point the stock header panel cant fit (IC sits to high).
I just moved to Denver (attending DU), I would love to stop by some time and take a look at that beast!
Small Business Partner
