WTB: 944S2 or 968 Exhaust camshaft
I may have a good one from a 968. I know one cam lost a tooth, but think that was on the intake side. I can check tonight when I get home. I'll shoot you a pm later.
Careful here ; the number of teeth on 968 is different than in S2.
I have A-class condition camshafts but they are herer (in europe)
But, you can use 944S exhaust cam ; that'll give you little power-hike too.
I plan on using a twin cam gear setup so I'm not really concerned about the number of teeth.
However, I would like to know the profiles for each.
How is the profile in the 944S cam different that it will net more power?
This will be a turbo application so everything will be different, but I'm still interested..
Exhaust opens 36 degrees before BDC on the S cam and 39 degrees before BDC on the S2 cam. Exhaust closes 4 degrees before TDC and the S cam and 7 degrees before TDC on the S2 cam. I'm getting this info from the workshop manual, not sure about duration and lift.
