Can't put the car in gear!, or "Is this Linkage Correct?"
I'm speculating from looking at the diagram above. But I believe that loosening "G" will allow the shift **** up front to move relative to the shifter assembly on the tranny. You should be able to align the shift **** into correct position by moving left & right; as suggested try to get it almost straight up for gears 3 & 4.
As far as gears 2 & 4, remember that the shift mechanism on the tranny moves in same direction as the shift **** in the cabin. Pushing forward (gears 1, 3 & 5) cause the rod "C" to move towards the front at the tranny. Gears 2 & 4 would have the rod moving backwards. I think you need to adjust rod "C" further out of the coupling, or adjust at "F" have the shaft going into the tranny turned more clockwise. But if there's a detent in the shaft for "F", than moving "C" may be your only option.
Last edited by aj986s; 09-10-2009 at 04:42 PM. Reason: had wrong direction. fixed in bold
But adjusting the rod makes sense. I think you may be on to something...
My bad...you're correct. I'll amend my earlier post. The pivot below the shift **** is at the bottom. So the shift rod moves in the same direction. So needs to adjust C to move back further. I believe that "E" and "H" only affect the ratio or throw length, based upon which hole is used.
yes, maybe not that much...but less length
try pushing it into 4th from under the car with the collar loose
lever arm forward
also make sure the lever arms position on the shaft allows the shifter to be pretty much straight up, not side to side...in 4th gear position
on your second pic in the 1st post...you see the machined area NOT in the collar?
loosen the collar screw, and shove the lever (and shifter) into 4th, then tighten the collar...
lever arm forward
Hmm. This sounds simple enough. Just a matter of having clearance for each gear. I'm leaving work soon so I'll be able to play with it.
I only have tonight though, I have to pack up the car and head to the Glen.
so the shaft needs to go rearward...
put shifter in 4th
loosen the collar and manually force the lever rearward into 4th...
also slide the shaft in/out to make the shifter ~straight up...
then make sure you can engage all gears...
The collar wasn't really the issue here, it was the bracket holding it in the rear. After having my girlfriend spend some time shifting through the gears and watching it work, I gained a much better understanding of exactly how the mechanism works. Then, after thinking about and taking into consideration all of the above advice, I reset the mechanism in gear 4 and centered everything. A quick tighten-up of all of the bolts, and it was working great.
Now, it still has a weird feel to it. Like I could move the whole H pattern side to side if I leaned on the shift ****--kinda hard to explain.
But, it's all set. And tommorrow morning my girlfriend and I are chasing my father in his Vette' up to Watkins Glen.
Thanks guys!
Thanks guys!
