Head removal ?
Jane Bond 007
Head removal ?
No, not MY head!
I've got the head bolts out and taken the header nuts off. The head is loose. Is there any way to get the head out w/o removing the header as well? I do NOT want to crawl under this *%$#ing car for 3 bolts <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" />
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by MichelleJD:
<strong>I do NOT want to crawl under this *%$#ing car for 3 bolts <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">How about crawling under for 6? They're all 13mm, just use a 12" extension and it's cake...5 mins tops.
On a 944/951 the headers come off with the head.
There is not enough clearance between the engine and the fender to pull the header off of the studs. So you will have to disconnect the headers from the exhaust system.
Unless you have a lift at home.....crawling it is.
<strong>Is it a bolt and nut? DO I need to hold the nut while turning the bolt? Ooooo I'm so close!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Yes to all the above. Again, 13mm for the wrench to hold the nuts [ <img border="0" title="" alt="[Eek!]" src="eek.gif" /> ], they're not welded to the header flange.
Jane Bond 007
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Bill:
<strong>On a 944/951 the headers come off with the head.
Unless you have a lift at home.....crawling it is.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva"><img border="0" alt="[crying]" title="" src="graemlins/crying.gif" />
Jane Bond 007
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by PorscheG96:
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by MichelleJD:
<strong>Is it a bolt and nut? DO I need to hold the nut while turning the bolt? Ooooo I'm so close!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Yes to all the above. Again, 13mm for the wrench to hold the nuts [ <img border="0" title="" alt="[Eek!]" src="eek.gif" /> ], they're not welded to the header flange.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva"><img border="0" alt="[crying]" title="" src="graemlins/crying.gif" /> <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" />
"Is it a bolt and nut? DO I need to hold the nut while turning the bolt?
Yes you do. That's more of Porsche's service-engineering for ya. I don't need to mention that certain other 'import' manufacturers weld the nuts onto the flanges in anticipation of this exact procedure. The very first time I took my headers off, I brazed some stainless nuts onto the flanges.
Here's an easy way to remove the headers from the rest of the exhaust. You'll need these tools:
- 13mm open-end/box wrench
- 3/8" ratchet with 'persuader' handle extension
- 3/8" extensions in 6", 3" lengths
- 13mm universal socket (that's a socket with a built-in universal joint, not a 13mm socket on top of a universal adaptor, this is the secret weapon...)
Easiest to start on the outside bolts. Assemble the proper combination of extensions to reach up. Best to have an assistant hold the wrench on the top side. If not, you can arrange the box-wrench such that the spin turns it into the header pipes and holds it in place as you turn the bottom. The two inside nuts & bolts require you to access them from between the header pipes. A little more difficult, but it can be done. This is where the 13mm socket w/universal pays for itself.
Also beforehand, apply PB-Blaster and let sit overnight. This will help loosen the rusted nuts & bolts. Replace with stainless-steel ones afterwards.
You might also want to replace the exhaust header studs. If you go down to your Toyota dealer with one of them (also Saturn), they can get you a replacement with an allen-key hole on the outside. This will allow you remove the studs the next time and remove the headers without having to pull the head.
Good luck!
Good luck!
