86 951 Hose Reference Needed
Former Vendor
This is probably everyday stuff for you guys, but I'm kind of lost in "another world" and could use a reference.
I've got a cracked hose that goes from the "tube" assembly under the intake manifold to the big boot that goes from the turbo to the airflow meter. The hose is about 25mm and makes a 90 degree turn in the middle. It used to be only available by buying the entire "tube assembly" under the manifold (951 110 061 03), but certainly, someone must have found a hose from a Zundop, or whatever, that replaces this hose, by now. Picture attached.
Sorry if this is real common for you guys and you're tired of
idiots asking the same question over and over.
![Name: DSC00687.JPG
Size: 60.8 KB](https://rennlist.com/forums/attachments/924-931-944-951-968-forum/381305d1251332624-86-951-hose-reference-needed-dsc00687.jpg)
Lindsey Racing makes a few of the NLA vacuum hoses - I think that one is this guy:
http://www.lindseyracing.com/LR/Pors...R-AOS-104.html
You can just cut off the collar to get the fitting out of the original, and use a hose clamp to install it in the new hose.
This is the early hose for 86 to early 88s.
http://www.lindseyracing.com/LR/Pors...R-AOS-103.html
More info here.
http://www.lindseyracing.com/LR/Parts/AOSHOSES.html
