944, what to look for?
Cruisin'
New guy here, I'm going to look at a '84 944 that has been sitting for about 2 years. In talking to the owner he says the only thing really needed is paint. He bought the car several years ago from the original owner and after a year of driving the timing belt broke. He replaced the '84 motor with an '86 motor w/ 54k, and has put another 30k on it. So, my question, what should I be looking for when I go and check this car out?
Odd Posts
I would stay away and seek to acquire something thta has been running and maintained (unless he is giving this one away). Count on a minimum of $2K in maintenance right out of the gate (belts, rollers, wp, all new fluids and probably brakes) if not closer to $3,500 (depending on what you can do yourself).
yeah, i must have glanced over the 'sat for 2 years' part. Those are the most trouble...and easiest for the owners to 'play dumb' with. Unless he's giving it away and/or you really want a project - I'd stay away from it. There are plenty of running examples for sale these days and it's definitely a buyers market.
If the new engine had 54k when installed, and he put another 30k on it, it's due for the TB and BS belt, for sure.
PS -- where are you?
1+ for the avoid it unless its free vote.
Any car that has sat for a period of time is going to have issues. And right now its way to easy to find a good running 944 for not that much money. Seriously, do yourself a favor and don't buy the first 944 that you find. Take some time and find a good one.
Cruisin'
I was told (take that as you will), that the car has been started regualrly and driven around the neighborhood. The only "known" problems is a door latch that does not work on the drivers side. Are timing belts due every 30k on these cars?
Be sure to check the clutch; both for wear (thru inspection hole) and for a sheared rubber center disc (thru the hole at the rear bellhousing. It only takes about 5 minutes but you need to get under the car to do it.
Unless he can produce a receipt for new belts AND all rollers/tensioners, assume it will need them.
Cruisin'
Where is the inspection hole, and what am I looking for?
so say one does buy a parked car... ca i drive it home? or is that goin to stress the belts etc? (home ideall is within an hour or two of driving)
t
y
s
t
y
s
Cars that work great don't sit for 2 years... The term for those is parts cars.
my car sat indoors (guy had 911, two m3s, and more) it ran great so i bought it, did belts, and in 12 months these rubber items failed:
oil cooler seals
clutch
a/o seal
tb seals
ps rack seals
oil cooler seals
clutch
a/o seal
tb seals
ps rack seals
