Towing points for a 944?
Can you get a 944 onto a flatbed from the back? Or is that practice frowned upon?
Where are the towing points for a 944? (Front and back)
The car I'm having towed doesnt run, so it will be winched onto the flatbed.
Any advice is appreciated, I don't want the tow guy to mess anything up.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi, I saw a way to pull a 944 up onto a rollback. You use a strap that goes forward up and over the transaxle to form a "Y" and is pulled backward up onto the rollback. I towed a 944 from NC to mid Ga. with a 2 wheel dolly that had straps that fit over the front wheels with no problem. I had to use 2ea 2"X 8"X6' as extensions to push the car up onto the tow dolly. There really isn't a standard way to tie one down except to put straps thru the wheel spokes. You can buy tow plates that attach under the rear on each side.
Cheers,
Larry
Cheers,
Larry
I have towplates if you're interested but I've always found the easiest way to get the car onto the trailer from the rear is just to put the hook from a winch through the hole opening that gives you access to the rear bumper shock. Once it's on the trailer the best place to strap to is a wheel. Below the suspension is always best to avoid getting slack on the tie downs when the car bounces around.
