It's getting hot in here, you better.. Roll up the windows??
Old 08-13-2009, 01:10 PM
krystar
krystar's Avatar
Originally Posted by ZW 944
Ok, I understand.
Any Idea why it cools down when I roll up the windows? In my opinion if it were just the foam then it wouldn't cool back down...I happened to come accross this little oddity by chance but have repeated it several times and got the same results.
most likely because when you open the windows, it produces a negative pressure in the passenger compartment. thereby any positive pressure air would be sucked into the passenger compartment by whatever holes are there.
Old 08-17-2009, 11:51 PM
ZW 944
ZW 944's Avatar
Ok, that is making some sense. thanks for your input.
This may be a stupid question, but.... is there any way that the heat could be coming from the torque tube? occasionally it will make this weird occilating (sp?) sound from the bottom of the bellhousing area. only noticable at idle or at low engine speeds. the sounds speed up with engine speeds untill they are drowned out by the engine at about 1300 rpms. (The car is an auto by the way)
I'm yet to find an obvious exhaust leak, still looking.
Old 08-18-2009, 10:24 AM
thirdgenbird
thirdgenbird's Avatar
fyi, the foam will go through the shifter hole one the shift lever is removed. i did it with a 20+ year old used and only tore it slightly. i would think a new, more pliable one, would go in well.
Old 08-18-2009, 12:05 PM
ZW 944
ZW 944's Avatar
Oh, Thanks for the info, thats good to know.
Old 08-18-2009, 01:23 PM
thirdgenbird
just take your time
Quick Reply: It's getting hot in here, you better.. Roll up the windows??
