ISV and weird throttle/idle response with cold.
edit: Rechecked the symptoms, 4 posts down
I've got an interesting problem on my 86 na. The whole top end was rebuilt and it starts and idles without issue.
When the car is cold, giving it some throttle from idle makes it stumble a bit in the 1000-1800 rpm range, once you hit 2K rpm it works fine and none of this happens when the car is nice and warm. Idea ideas what that could be?
bump so here's what happens:
The car does start but the idle stumbles for a second or two, then the rpms shoot up to 1500 and come back down and sit steady at ~1000. If I give it full throttle from 1000rpm it nearly dies before shooting up. Any idea?
Can it be dirty/bad ISV?
1 Post
Could be a bad AFM?
Check this guy's video on a cool little tweak: http://www.youtube.com/watch?v=-11J8...om=PL&index=17
Sprint.
My '86 Turbo does the same but I don't think it's weather or catalyst or oxygen sensor related. Why? Becoz here in Singapore, it's hot all year round, my RoW car hasn't got a cat nor O2 sensor. I think it's to do with the cold start enrichment. Is the original poster running stock chips or aftermarket?
Sprint.
Sprint.
