I need help/advice badly. Oil Pan destroyed.
I've got an oil pan from a 1986 944 turbo that will fit for sure that I will sell you for $75 shipped. You will definetly at the very least need a new oil pan gasket and I would go ahead and replace the plastic baffle that bolts into the bottom of the pan and also the seal on the oil pick - both easy items to do while you are in there.
You will need a torque wrench to properly tighten the bolts down on the oil pan and it is very important to follow the factory directions to ensure you don't have leaking problems in the future.
Now that I think about it you are going to be pulling off the crossmember so if you think you motor mounts are close to being worn out now would be an excellent time to replace those.
When pulling the crossmember don't forget to undo the power steering line that attaches to the top of it.
Welding in-situ sounds pretty iffy to me. You've got the plastic baffle, residual oil in the pan that could catch fire, heat conducted up to the pan gasket or end seal could result in big leaks... If you must go the patch route as a temporary fix, I would suggest trying some oil resistant epoxy with an aluminum sheet patch. Make sure you wipe down the contact surface with lacquer thinner, etc. so the surface is absolutely free of oil.
1 Post
Thanks everyone for your help so far.
xsboost90 hooked me with a great deal on an oil pan, and the rest of you have given me plenty of advice. I'm sure I'll be posting more as the work goes on...
This community never lets you down
1 Post
Update!!
Welp, started tearing into it saturday. 5 hours later I had the oil pan off. Dear god...some of those bolts. There were two or 3 bolts on the oil pan itself that I had MAYBE a inch of wiggle room to use my fingertips on.
Those and the motor mount bolts were the worst. I cringe thinking of putting this back together. Oh well. Its halfway done. My gasket never showed up on Friday...and the online tracking says it was sent to an undeliverable address, and lists my exact, correct address. Very frustrating.
Anyways, the only mishap so far is a bent power steering line.
Hopefully I'll be back on the road this week sometime.
edit:
Yeah, didnt do this.
edit:
Hey Man
Update!!
edit:
Yeah, didnt do this.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
edit:
1 Post
So I should be ok there. Worse case, this job will be much easier the next time I have to do it.
I'll take some pictures to show where the damage is.
