Who has ever had a broken timing or balance shaft belt?
Changing the belts on my 951 was pretty complex due to the turbo and associated plumbing. I was dreading this job at first, but it wasn't as bad as I thought it would be. For anyone considering it I would definitely advise doing it yourself. The tool club set has everything you need, I used a white-out pen to mark EVERYTHING before I took it apart, and put all screws...in ziplock baggies (labeled) as I went. I set up a big piece of cardboard and set up all the rollers, gears, washers..in place as I took them off, then carefully compared the new parts as I put them on. It was slow, but everything went together like I knew what I was doing.
Arne.
Arne.
