Has anyone tried using these?...Lower Shock Mount
Paragon products now sells lower shock mounts for $75/each that look like they could be used with any coil-over shock. The only shocks they reference are the high-dollar Koni's, but what about less expensive ones like those listed in JC Whitney. I don't want to race my car, just not go through the PITA of replacing the torsion bars like I did on my 951. Anybody try these shock mounts?
Hi David!
The lower shock mounts are built by Racer's Edge, and will work with any shock or coil-over that uses a 1/2" ID lower eye. The purpose is two-fold; to significantly increase the load capacity from that of the stock bolt, and to move the lower mount slightly away from the arm to allow more clearance from the shock to the control arm.
