Removing Taillights and License Plate Lights, Help!
I thought it would be easy to take the taillights out... I took the light assembly off and removed about 5 nuts that were holding the lenses on. But it won't come off! I don't see any other thing holding it on unless the lenses are glued in really good. Does anyone know how to take the lenses out?
On a similar note, I can't figure out how to take the license plate lenses out either... It almost looks like they're riveted to the body of the car, but that doesn't make sense, how would you ever be able to replace them?
I trust at least one of you will know how to get these out
Did you get the tail lights off? There are 6 bolts holding each one on. Than there is the old dried black clauk sealant.
Go slow and take your time so you do not to crack the plastic lens pulling them off.
