oil cooler inlet and outlet schematic
I am looking for a layout of what hose goes in and what hose goes out of the 944 turbo oil consoul at the oil filter.
I am replacing the stock oil cooler with a larger one and adding a check valve for the accusump, so I really need to know which way to put the check valve.
Ed
Ed
Herr Unmöglich
The line to the rear of the car is where the oil exits the block and heads to the oil cooler. The return line to the car enters from the front of the filter plate, right next to the oil pressure sensor.
