Are all 944 S2 torque tubes the same?
Old 07-29-2009, 04:54 PM
ScottS2
ScottS2's Avatar
Default Are all 944 S2 torque tubes the same?
Hello to all. I have a simple yet important question: Are all 944S2 Torque tubes the same? In other words, will a 1990 S2 torque tube fit in a 1989 S2?
Thanks in advance for your help
Scott
Old 07-29-2009, 04:59 PM
Wipeout
Not Special
Wipeout's Avatar
All torque tubes for the 944 are the same, period.
Old 07-29-2009, 05:44 PM
ScottS2
ScottS2's Avatar
Thanks for your reply.
I was told by my local Porsche boneyard that some 944s (I assume later model years) had a "split" torque tube. I notice that mine has a lengthwise slit at the forward (engine) end that is roughly 1.5 ft long.
Thanks again.
Old 07-29-2009, 06:01 PM
Wipeout
Not Special
Wipeout's Avatar
The split is there on S2s, but not NAs (not sure about the turbo). Supposedly it's there for crashes; torque tube becomes a crumple zone. There was a good thread about it about a month ago.
I have the TT out of my '85 that I will probably rebuild and put into my '89 S2.
Old 07-29-2009, 06:15 PM
PorscheDoc
PorscheDoc's Avatar
I have only seen the split torque tubes on the S2 and 968 Cabs, but others may have it. The half dozen S2 coupes I have done clutches on, did not have the split TT. We did swap a 951 TT into an S2 cab which had a bad TT a few months ago.
Old 07-29-2009, 07:23 PM
Chads996
Chads996's Avatar
WRONG. The split is on S2 TT's. I was told it had something to do with the harmonics/vibration. Also, the S2 has an inspection port on the aft bell. Others do not.
Something also to consider - the S2 is a hodge-podge of Porsche parts. Upon speaking to a few tech's about the S2's, they mention finding forged rods in the engines. There is also further proof of the variations of the parts through the life of the S2's. Example: the clutches mechanism (master, slaves and lines..) differ on the '89's versus the '90 & '91. In 1990 & 1991, they started bringing the 968 electrical harnesses and mechanicals into the car. The 1989 electrical harnesses are more similar to the 1989 turbo than the later S2.
From my build, I have learned a ton about what a "mule" the S2's really were for Porsche's 968 development.
C.
Old 07-29-2009, 07:31 PM
ScottS2
ScottS2's Avatar
All good info. Thanks, gentlemen!
While we're here, here are a couple of more questions:
1) Is there a source for those bearing carriers that go down the inside of the TT?
2) Is there a source for the rubber/metal inner "race" that gets pressed into the TT bearings (the ones teh drive shaft slips down inside of)?
3) I'm assuming from what has been said so far that the drive shaft is the same for all 944s?
Thanks again in advance.
Scott
Old 07-29-2009, 07:47 PM
Wipeout
Not Special
Wipeout's Avatar
C.
Strange, I seem to remember from the other thread that S2 TT and other 944/951 TT are the same length, bolt patterns, etc. The difference is the slit, that's all.
...here's "the other thread"
https://rennlist.com/forums/924-931-...aring-pic.html
Old 07-29-2009, 08:14 PM
Chads996
Chads996's Avatar
Technically speaking, yes. The same bolt pattern, they will fit. However, you said that all 944 TT's are the same. They are not.
C.
Old 07-29-2009, 08:58 PM
Wipeout
Not Special
Wipeout's Avatar
C.
Touché.
How's the ubercar?
Old 07-29-2009, 09:06 PM
smlporsche
smlporsche's Avatar
I wonder where you got that info
C.
That is SOP for Porsche as they have done it for decades. For example some '04 Boxsters (986) have some 987 parts and there are several examples in the 911 line as well.
Those Germans are very frugal...
Old 07-29-2009, 09:09 PM
Eric_Oz_S2
Eric_Oz_S2's Avatar
Scott
1) The bearing carriers can be had from Jager for $150 ea (cough cough) - you probably won't need new ones though. If you did you would be better off getting a used tt
2) Again, Jager sells these for around $20 each. I am getting mine fabricated locally out of Acetal for a similar price'
3) Driveshaft is the same, except the S2s are coated with a kind of epoxy - the measured diameter is still exactly 25.00mm though (must be a really thin coating). The coating makes it more difficult to push out the shaft with a hammer, you are better off pressing it out with a jack and a 1.2m long length of 15mm/.5inch galv pipe.
Old 07-29-2009, 10:13 PM
ScottS2
ScottS2's Avatar
Thanks again for all the info. I even read the previous TT thread that Darren referenced and learned even more there as well. Dealing with the TT in a 944 can make you pull your hair out if you aren't informed. It's like a friend always told me, it's German, so there's a trick to it. If you miss the trick, you could be in a lot of trouble. If you know the trick, things usually go fairly smoothly. If it wasn't for the Rennlist, I'd be hosed. Thanks again.
Cheers,
ScottS2
ScottS2's Avatar
Cheers,
Old 07-29-2009, 11:14 PM
Tim968
Tim968's Avatar
The story of the slot is related to reducing torsional resonance in the driveline. It was patented by Porsche. See http://www.patentstorm.us/patents/5067582.html.
Quick Reply: Are all 944 S2 torque tubes the same?
