my 6.5" component speaker install
Well the story is that I had some 6.5" components from my last car, and since I really liked the sound of them I decided to find a way to mount them in the 951. I couldn't find much info on here so thought I would share my design in case others are looking to do the same.
First thing I did was make a cardboard template for the outline of the mounting plate. The depth of these woofers is around 1.75" so I calculated that I would need a 3/4" thick plate for the magnets to clear the window. Also, for the area where the door overlaps the side of the dash, the plate is recessed down to 1/4" thick so that the door will close. Then I spent some time finding the right location for the speaker cutout - took some trial and error as the window motor makes it a tight fit.
After I had the template made, I put it in position and cut out the door card material inside of the speaker cutout. This will then expose where the door metal needs to be cut as well. A shorty hacksaw works well on the door sheet metal. I didn't bother reinforcing the door metal because it will be stabile once the mounting plate is bolted to the door.
To make the mounting plate, I used 3/4" baltic birch plywood, and chamfered the edges. The corners on the bottom are rounded to fit inside the door cubby. Also, I plan to countersink and epoxy the bolts into the mounting plate, as well as paint it black.. just haven't got around to it yet.
To mount the plate, I figured out the locations where there was sheet metal to bolt through and marked the holes on the mounting plate. I then drilled the holes in the plate, put it in position on the door and drilled through the plate holes and through the door metal. The bolts are held on with locknuts on the inside of the door.
For the tweeter, I didn't have any mounting hardware so I just cut a hole and epoxied them to the door card. And the crossover just sits in the door cubby.. couldn't really find a better place to put them. I have the amp mounted in the spare tire well and was planning to add a sub, but decided that I really don't need it. The woofers put out some serious bass and anything more would just rattle stuff loose! Also, I disconnected the old stock rear speakers and have no plans on replacing them. If you have a good set of components in the front, the rears are just redundant.
You may want to hide the crossover under the dash out of the way and just run wires to the tweeter and midbass driver thru the rubber boot. Keeps them out of sight and damage. Looks pretty good. +1 on the vinyl wrap, and maybe grille covers. Nice work!
I don't know how big the amp you have is, but I put two amps on a plywood base that i cut to fit in the driver's side cubby. Made the wiring chore a bit easier for me that way and the way my amps are laid out, I can adjust levels easily.
