help needed! size of trans to torque tube mounting bolts
Help people.
Was under my car and discovered that one of the bolts that mates the rear of the torque tube to the transaxle is missing. These are the 4 bolts that go from the torque tube casting to the actual transaxle.
Does anyone know the size, length, tpi of all four? thinking I need to go to the hardware store and buy one to replace the missing one and stock up on the others too.
thanks in advance !!
tom
tom
Not Special
From workshop manual (you have the PDFs of those, right?), 30-09:
Central tube housing to transmission case
Threads M12 x 75, torqued 85Nm
Threads M12 x 80, torqued 85Nm
Threads M10 x 60, torqued 42Nm
