There is some info. on that in <a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic;f=15;t=015298;p=3" target="_blank">this link</a>
You can pinch off the hose that leads from the idle-stabilzer valve to the intake-manifold. If your idle drops, then the valve is open. Only do this if you have new hoses that are flexible. Otherwise, disconnect the hose and plug it and the port on the manifold.
