rubber cap part number?
Jus'kiddin...
cap - 944.106.103.03
clamp - N.024.511.3
You'll need two of each. If you have an updated car, they leave the nub on the T-belt cover, but block it off from the inside. Be sure yours is not updated prior to ordering.
Good Luck!
clamp - N.024.511.3
Good Luck!
and, here's a hot tip:
<img src="http://www.tech-session.com/images/hot_tip.gif" alt=" - " />
Do not spray belt lubricants into the belt inspection hole while the engine is running. Spark and oxygen are already present - completing the triangle can be harmful to facial hair.
