Heeeeeellllllllp! "please"
Old 07-17-2002, 11:50 AM
TaboII
Lifetime Member
TaboII's Avatar
Post
That was my own post. I got tired of looking for a hose that apparently did not exist and found a company that had steel breaded hose that woyld work eith the d4 break fluid. Thanks anyway
Old 07-17-2002, 12:29 PM
jim968
jim968's Avatar
Post
"He said that the braiding helps to keep the hose from expanding.
He said that if I didn't use it, I might have a soft clutch pedal. Do
you folks agree?"
Nope, I don't agree, at least in this case. Unless I'm really confused (easy to do to an old man ;-))... we're talking about the supply hose that runs down from the brake fluid reservoir to the clutch master cylinder...yes? It's open into the reservoir at the upper end... It's just a suction line, and since it's gravity-feed, the pressure inside is the same as the atmospheric pressure outside, other than the "massive" gravity-head pressure (in the 6" drop, about 1 psi, _maybe_). If the drop was 20 feet, I might worry about the need for braiding to keep it from expanding...
Any hose of the right diameter will work, as long as it will take the heat & not break down on exposure to brake fluid (which is fairly nasty stuff).
Jim, "You are slower than a herd of turtles stampeding thru peanut butter...."
Quick Reply: Heeeeeellllllllp! "please"
