What can make a 951 run rich? Problem Solved
Hey Man
BFE is Bum F*&%ing Egypt. When I say dedicated, I meant directly to the intake manifold. If there is a leak in one of the other things attached to the 5 port vacuum manifold, it will affect it. If it goes to a vacuum manifold, it isn't dedicated.
To answer your other question, yes. I'm not as familiar with Porsches as I am Fords (used to be an engineer there), but enrichment on a cold start is definately a common strategy. If your computer never realizes the engine is warm, it is adding fuel to make sure the engine runs reliably, as fuel doesn't vaporize as well on a cold engine.
Another option you may try is to adjust the mixture on the computer. Not sure if you know this, but on the back of the computer, there is a small dial. You can adjust the pre-set enrichment from that dial. I think dialing right adds fuel, and left takes it out.
Keep the ideas coming, I really do appreciate it
Hey Man
Anyway, I just did a look under the manifold and found the DME temp sensor in the block is covered with some heavy green deposits. It looks like a little coolant has been leaking between the plastic plug section and 1-piece brass body. A leak between the body and plastic can only be a failed tip as it's one solid piece of brass from the mounting surface to tip. As soon as I remove the IC pipe I'm going to test the sensor with an ohmmeter; the spares I have are both at 2100 ohms or above. If that doesn't help it's on on to other causes.
Gotta love these cars right?
Hey Man
I think I got it solved. I took the airbox off to test the DME temp sensor and checked the AFM door while I was at it. The sensor was fine. The AFM flapper wasn't closed all the way; poked it a few times and it wouldn't close by about 1/2". Took it off and it had almost zero spring pressure. I compared it to 2 good AFM's and they snapped shut and took much more pressure to move the door. It's also interesting that the bad one was a remanufactured unit with the Bosch parts number ground off. I took it out for a spirited run and it idles and runs so much smoother now with no fuel odor at idle or after fully warmed up. I do believe it's ready to smog now. I would also like to thank CPR for throwing in the AFM with the airbox I bought from him.
I hopefully won't have to come back again to post about some new smog issues. Thanks for all the help guys.
