what do i need? (rear swaybar content)
ive searched and im not clear exactly what parts i need to scavange of a wreaked 944. Im going to get the parts shortly, and have to remove then myself. can someone show me som pics of everything i'll need and its relative location please?
edit: also what tools will i need (socket sizes etc..)
1 Post
i had to do this same thing to my 924S
go to dcauto.com and they have diagrams of everything. it tells you all the bolt sizes that you would need. besides that you need the swaybar, the two drop links, the two center u-brackets and the bushings.
but yea yer right, bring a 13mm socket too. cause alot of things on this car are 13mm
thanks everyone. unfortunately, the guy didnt tell me the car was half buried old growth and in a briar patch. needless to say i didnt get them i did however get 3 script door handles
Do you mean the eccentric bolt threaded end to which the rear bar attaches? You will definitely need the eccentric bolts if there was no rear bar previously but everything else should be there. I did this upgrade years ago and the only thing I would recommend is that you use adjustable droplinks instead of OEMs to fine tune the suspension.
