Aftermarket airbags?
FWIW, maintenance doesn't need to be expensive in a 944. I've spent an average of ~$1000/year maintaining my 944 - of which ~$600/year is spent on race tires and ~$200/year is spent on race brake pads. Occasionally I'll hit a "bad" year where I need to spend an extra $500-1000 on the car with something like a timing belt change (or worse), but you'll get that with any car.
Anyone who knows me will vouch that my car isn't "driven easy" either. Of the ~5000 miles a year I put on the car, only about 500 miles of that is not either to or from a track event (at which point I'm towing a trailer with it) or put on at the track event.
Maybe after all the maintenance has been brought up to snuff, but for the first year, I don't see it being a cheap proposition. Even a well documented car will need some maintenance, and at a minimum I'd do fuel hoses, belts, rollers and front seals regardless of the condition of the car.
There's no such thing as a cheap Porsche no matter how you slice it. You'll end up spending $10k+ on a 944 or $15k+ on a turbo either up front for a well sorted (and minimal maintenance) car or for one that needs more attention (and considerably more maintenance).
After that maintenance costs should be minimal barring any catastrophic events. Personally I don't think these are good cars for a teenager.
Airbag systems are quite robust, I do not see why they would degrade. If the wiring is damaged you get a fault light. Ignitors and propellant should last for 50 years or more. Unless the car has been pre-crashed the airbags should work fine. I'm not crazy about the old-style high power airbags but they'd be better than just a seatbelt if some cell fone yapping SUV pilot overcorrects into the oncoming lane and knocks me into a tree.
-Joel.
-Joel.
No idea. There could be any number of reasons including disabled airbag systems, previous crashes, aftermartket replacement airbags... whatever I do not see the point. If the failure mode you are seeing is partial deployment or no deployment that does not mean it's better not to have them. Some of them will still work, more so in decently maintained cars with no significant accident history.
If what you are saying is that some 944 airbag systems might not work so 944 airbag systems are therefore not valuable or desireable, I reject that.
If nothing else they can lower your insurance premiums.
-Joel.
-Joel.
The simple fact of the matter is that airbag systems are NOT all that robust. No more so than most other automotive systems. If the wiring is damaged IN THE RIGHT WAY you get a fault light. There are plenty of failure modes that show no indication to the driver. This is not news; firefighters and paramedics consider it a given, and I have personally observed it more times than I can count over the course of the last 15 years.
I have to pull people out of cars that SHOULD have deployed (or only partially deployed) enough times that I actually have a kevlar bag that I can toss over the steering wheel and tie off to try to minimize my (or my patient) getting hit in the face with an airbag after the fact while I'm getting them out.
I can't wait until the cars with all of the side curtain bags and seat-deployed bags start screwing up and not fully deploying. There's simply no way to secure all of them, save disconnecting the battery for however long the ERG says should de energize them (which usually isn't an option time-wise - its often about 10 or 15 minutes, sometimes more).
And when this happens, unless someone gets killed and there is a law suit, nothing ever really happens. Except for one time in my experience - a 3 year old Saab. Saab actually called the fire department to find out if we had any more pictures or information and interviewed me over the phone. There was no law suit, but the dealer had been called to remove the car after the wreck and somebody there called corporate and they actually wanted to get to the bottom of what happened. I was very surprised.
Almost Addicted
Am I the only one thinking he should buy the car he wants and just throw an airbag steering wheel on it and call it a day?
Buy the 944 - ditch the air bag idea.
Spend the money that you'd spend on trying to do some kind of air bag conversion and spend that on defensive driving classes or track training.
Explain to your parent what you want and why - and what you'll do to allay their concerns. (Maybe do some extra chores or something, too...)
Lazer Beam Shooter
-Joel.
-Joel.
I still do not see the point... OK airbags do not work 100% of the time, OK they sometimes present some danger after a crash. Are you trying to downplay the effectiveness such that having or not having airbags should not be a consideration at the time of purchase?
I think they are better to have than to not have, given the option.
-Joel.
So I'm sort of at a loss over this whole airbag thing... I like the idea of taking an advanced driving course. I think my dad would be all for that, but my mom is super stubborn. She'll most likely tell me "No airbag, no car."
Under the Radar
It's well known within the E36 community that the side impact airbags installed on 97 and 98 cars don't always go off. You could attribute this to a rudimentary system (computer isn't good enough to properly sense many kinds of side impacts), or the aging materials. So what you're left with is a pain in the neck that will detonate on you if you're not careful when removing it to service the window regulators. And it *might* be useful if someone T-bones you pretty perfectly.
Let's be honest. Aside from handling, brakes, and the transaxle concept, the 944 is not really well known for having well thought out anything. I'm not saying that like it's a bad car. The 1977 924 engineers didn't envision the car eventually being fitted with 4-piston brakes, a turbo, vacuum climate control, ABS, airbags, electric seats, locks, a convertible model, etc. Welcome to Porsche- I don't think Butzi Porsche envisioned a 930 when he came out with a 2 liter 911 in 1964. Anyway, I don't think any 198x airbag system is going to be terribly advanced, and I wouldn't trust a 20 year old system to work.
To the OP: Show your parents the general consensus by car manufacturers about the useful life of airbags, and illustrate that most of the decent cars you can afford will be plagued by this issue. The 944 is a very dense, well built car (general metalwork and steel thickness is better than any 3-series IMO), and takes crashes very well, assuming that the other vehicle isn't a lifted pickup.
What can you do in terms of your own service work? If you can do most anything but windshield replacements and transmission overhauls, plan on $1000 a year. That includes wear items that you'll pay for with any car.
In terms of insurance cost, my brother's 89 S2 with ABS and dual airbags was about equal to my 83: +/- $20 annually. I have had one at-fault accident, and he is clean.
The funny thing is, I agree haha. Most teens don't realize the maintenance required to keep these cars running. It's just a chick magnet to them... However not all teens are created equal... I'm pretty sick of people ASSUMING I'm irresponsible just because of my age...
If I was looking for something cheap and reliable, I'd be looking at an Asian car. For something German, VW or BMW (at least the parts will be cheaper). I'd love to have a BMW 318ti Sport...
