Need a Part#
Need a Part#
For the bleeder screw crush ring...
bonus points if anyone wants to give me a copy of PET or knows the part # of a NAPA/autozone crush ring that is compatable.
Cheers!
Cheers!
If you're referring to the coolant bleed screw crush washer, the PET part number is: N.013.830.7.
The OE are made of aluminum. The size is -> Outer Diameter: 12mm, Inner Diameter: 8mm; Thickness: 1mm.
You can download a free PDF copy of the PET catalog from www.porsche.com. Select country (USA), select "Personalization and Service," then "Porsche Classic," then "Classic Catalogues," then go to "Porsche Original Parts Catalogue as PDF" and choose model and year (note there's an 85-88 version and an 89-91, depending on your 951). Click on display, and wait for the PDF to load, as it's over 10 megs. Save a copy and it's yours!
HTH.
HTH.
