i gave it a power steering pump.... now what does it want from me
Rich-
A pump rebuild kit is less than $10 and the repair is easy. Do a search...it's been covered. This will cure your leak at the pump halves. I purchased my kit from Transtec.
Rich-
This may be a double post...I posted but it didn't show up? Weird. Anyway, to repeat, rebuilding the ps pump is cheap (~$10) and easy. You can get a kit from Transtec. That will solve the leak at the pump halves. You can actually rebiuld the pump without removing the rear half, and therefore save yourself from disconnecting the hoses and replacing the crush washers (unless they are leaking of course). Do a search...it's been discussed.
EDIT- Ok I am an idiot. My post was the first on page 2.
