Time for a new clutch or not?
I didn't have a measuring tool with me when I checked the clutch inspection port.
Do you think I need a new clutch yet or not? The friction point is very very high (maybe 1" from the top) in the clutch pedal's travel. I know the instructions say that 34mm+ needs a replacement, but 34mm is about 1.3" and I can't imagine that that distance was 1.3", but then again, I don't remember how big the hole is.
Thanks for the help!!
Also, I stuck my finger in there and I did not see any rubber marbles. Is this a good sign?
Is the clutch not working properly? If it works and you have no other reason to pull out the tranny and torque tube, drive it until it it starts to slip or the rubber donut (if so equipped) shreds. Doing a clutch on one of these as preventative maintenance is not typical but hey, if you've got the time and money...
Proprietoristicly Refined
Good picture.
Instead of sticking your finger in the hole, take out the starter and fish around there.
You have a 1986 944. In the past 18 months I have replaced a clutch in my 1988 924S 60K and in April this year my 1987 924S 113K--both with OEM rubber disc failure. You are living on borrowed time if your car still has the rubber clutch disc.
Measure the hole opening more carefully. Put a deep socket in the hole that just barely fits. Take it out and measure. You may not have rubber disc failure yet but you are going to be down to your disc rivets soon and you may ruin the flywheel.
The job is DIY if you have a big floor jack and can turn a wrench. Parts? $800 to $1000 for the clutch kit and a few extras as you go along. Shop time is 14 hours and you pay the markup on parts.
GL
John_AZ
1988 924S + 1987 924S
GL
John_AZ
I dunno, the clutch release point is so friggin' high--I can't really drive the car the way I want to it seems. I also wanted to take this car to the track at some point and it seems like this issue is going to dash my hopes.
Well, I got a quote of about $650 for labor from a reputable shop for the clutch change/flywheel resurfacing and I found this clutch kit for about $507 shipped:
http://www.autopartswarehouse.com/de...3-1597372.html
BTW, is that one any good? I'm really not going to use the car for much track use--just maybe once or twice.
I can't do the clutch change myself because I don't have a place to work on it hardcore--just an apartment parking lot (and technically my lease forbids working on my car here).
http://maps.google.com/maps?hl=en&um...16979173809362
The Bug Shop in Blacksburg, VA. South Main Auto quoted me over $800, which is still not bad.
Pilot bearing
TO guide tube
needle bearings on fork shaft
fork shaft if really pitted by bearings
rear main seal
MUST-new flywheel bolts
Maybe new PP bolts
New transaxle fluid-synthetic GL4 is best
exhaust manifold gaskets
MAYBE a new reference sensor when an old one cracks
Miscellaneous grease, cleaners.
TO BE Continued...
GL
John_AZ
.....I agree there has been debate on whether to replace the fly wheel bolts. I prefer to replace the bolts that are subject to stress and stretch.
amac944, does your clutch master cylinder leak inside the cabin? You should check for drips of brake fluid coming from the boot above the clutch petal. If you do see a wet boot, it is time to replace the clutch master cylinder. It is also suggested to change the clutch slave and lower slave hose at the same time. There is a rebuild kit for the clutch slave~$25 that can be used if the bore does not have pitting.
GL
John_AZ
GL
John_AZ
My master was leaking and when I checked the slave, it was also leaking . Well did both and a starter that was also in need of replacement. All is well now. Oh and thanks for all the info here at Rennlist.
