Looking for interior trim piece
Im looking for the black plastic cover that goes on the left side under the drivers footwell. That covers wiring. Mine is split right down the middle. Anyone have one from a parts car ?
From: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Is it part number 944.610.219.02 -- which covers the fuse box from below (driver's well)? If so, I have one that I was going to throw away -- you can have it for cost of shipping plus cost of beer.
87+ is part number 944.610.219.02.
Just a heads up - installing it is a PITA. At least mine was, but that may be because I rebuilt my entire harness and it's freshly wrapped. I had to lift the fuse block up to get the cover installed, then I had to try to get all the wires tucked up inside it enough to put the fuse block back down on its mounts.
If you do need to pull up your fuse block, make sure you disconnect the battery first!
